Article ID : 00366428 / Last Modified : 20/01/2026Print
The lens vibrates when the shutter button is pressed halfway or the AF-ON button is pressed with Pre-Capture set to On in AF-C focus mode.
    The lens constantly focuses before each shot to enable precise AF in continuous shooting, including when pre-capture is used, which may be felt as vibration or sound.
    This is not a problem, because the operation is the same as in regular continuous shooting without pre-capture​​​​​​.
