Article ID : 00082289 / Last Modified : 05/05/2014Print
    How to access the File Explorer
    There are four different methods you can use to access the File Explorer:
    • Press the Windows Logo + E key combination.
    • Press the Windows Logo + X key combination, and then click File Explorer.
    • In the new Windows User Interface (UI) Start screen, point to (but do not click) the lower-right or top-right corner of the screen, and in the Search field, type File Explorer and then press the Enter key.
    • In the new Windows User Interface (UI) Start screen, click the Desktop tile, and on the Taskbar, click the File Explorer icon.
