Article ID : 00231411 / Last Modified : 18/06/2026Print
Limitations on recording 14 bit images in RAW format
    RAW images recorded using the following models have a resolution of 14 bits per pixel. However, the resolution is limited to 12 bits under certain shooting conditions.
    These limitations are described in the File Format (still image) section of the Help Guide. 14 bits recording of RAW images is always possible for models that do not have limitations in the File Format (still image) section of the Help Guide.
    ILCE-7RM6
    Shutter Type: Electronic Shut
    Single-shot shooting *1Continuous shooting *2
    Compressed RAW14 bits12 bits
    Compressed(HQ) RAW14 bits14 bits
    Uncompressed RAW14 bits14 bits
    DSC-RX1RM3
    Single-shot shooting *1Continuous shooting *2BULB shootingLong Exposure NR is activated *3
    Compressed RAW14 bits12 bits14 bits14 bits
    Uncompressed RAW14 bits14 bits14 bits14 bits
    ILCE-7 / ILCE-7R / DSC-RX1 / DSC-RX1R
    Compressed RAW14 bits12 bits12 bits12 bits
    ILCE-7M2 / ILCA-99M2 / DSC-RX1RM2
    Uncompressed RAW14 bits12 bits12 bits12 bits
    ILCE-7S / ILCE-6100 / ILCE-6100A / ILCE-6300 / ILCE-6400 / ILCE-6400A / ILCE-6500 / ILCE-6600 / ZV-E10
    • Silent Shooting: Off
    • Silent Shooting: On
      Compressed RAW12 bits12 bits
    ILCE-7RM2 / ILCE-7SM2
      Uncompressed RAW12 bits12 bits
    ILCE-7RM3 / ILCE-7RM3A / ILCE-7M3 / ILCE-7RM4 / ILCE-7RM4A / ILCE-7C
      Uncompressed RAW14 bits14 bits12 bits12 bits
    ILCE-9
    • Shutter Type: Mechanical Shut
    • Shutter Type: Electronic Shut
    ILCE-9M2
    ILCE-7M4 / ILCE-7RM5 / ILCE-7CR / ILCE-7CM2 / ILX-LR1
      Lossless compressed RAW14 bits14 bits14 bits14 bits
    • Shutter Type: Electronic Shut or Silent Mode: On
    ILCE-6700
    • *1 Single-shot shooting includes self-timer shooting and interval shooting.
    • *2 Continuous shooting includes multiple burst shooting under Superior Auto mode, continuous shooting under self-timer mode, and continuous bracket shooting.
    • *3 Long Exposure NR is active when it is set to On and the shutter speed is set to 1 second or longer.
    Note: JPEG images will be recorded in 8 bits.
