The indicator does not light up, even though DSEE HX or DSD Remastering is set to ON
The DSEE HX indicator does not light up even though DSEE HX is set to ON.
[A]: DSEE HX indicator
If an incompatible input signal is received and DSEE HX is set to ON, the DSEE HX indicator lights up and turns off immediately.
DSEE HX works only with the following formats:
Sampling frequency |
Bit depth | |
PCM (Pulse Code Modulation) | 32 kHz | 16, 24, 32 |
| 44.1 kHz | 16, 24, 32 | |
| 48 kHz | 16, 24, 32 | |
| 88.2 kHz | 16, 24 | |
| 96 kHz | 16, 24 | |
| 176.4 kHz | 16, 24 | |
| 192 kHz | 16, 24 | |
| 352.8 kHz | 16, 24 | |
| 384 kHz | 16, 24 |
The DSD RE. indicator does not light up even though DSD Remastering is set to ON.
[B]: DSD RE. indicator
DSD Remastering is only available with the PCM format signals. DSD Remastering does not work on the DSD format signals.
