Article ID : 00108798 / Last Modified : 27/07/2026Print
    What is the difference between Reset Default / Camera Settings Reset and Factory Reset / Initialize?
    • Reset Default / Camera Settings Reset function
      The settings for the main shooting modes will be reset.
    • Initialize function
      Reset the settings that the Reset Default / Camera Settings Reset function does, as well as other settings such as Date/Time Setup and Wi-Fi Settings. In addition, Face Memory, File Number, and downloaded applications will also be deleted.
    • Factory Reset function
      Reset all the settings that the Initialize function does, as well as AF Micro Adjustment settings.
    Notes:
    • The available functions may vary depending on the camera model.
    • Do not turn the camera off while resetting.
    • The camera may show a blank screen for approximately 10 seconds after performing a reset. This is normal operation and not a malfunction.
    • The functions that will be reset vary by camera model. For details, please refer to the Help Guide (Instruction Manual) for your camera.
