Applicable Model
This information is for the following models:
  • ILCE-9M2
About this download
Benefits and Improvements
IMPORTANT: When you update to this version, the camera settings will be reinitialized. Because of this, we recommend that you save the current settings before updating. You can use the Save/Load Settings function to save the current settings to a memory card and write them back after the update.
NOTE: For details on how to save the settings and the items that can be saved, refer to Save/Load Settings in the Help Guide.
  • Adds the Crop function to allow you to crop a recorded still image
  • Adds the Forced File No. Reset option in the File/Folder Settings (still image) menu to allow you to reset the still image file number and create a new folder
  • Other improvements
    • It is improved the phenomenon that some functions are not registered correctly in the Function menu
    • Improves the overall stability of the camera
NOTE: Please refer to the Help Guide for updated function usage.
Previous Benefits and Improvements
View previous benefits and improvements
File Info
File Name
  • Update_ILCE9M2V3.00.dmg
File Version
  • 3.00
File Size
  • 328 MB (328 014 840 bytes)
Release Date
  • 10-03-2021
Preparation
Check the system software version
Follow the instructions below to check the system software version. If the system software version is Ver.2.00, the update is not required.
NOTE: If the Date/Time setting screen appears when you turn on your camera, be sure to set the date and time to the correct values.
  1. On the camera, select Menu → Setup6 → Version.
  2. The system software version is displayed as illustrated below.
    System Software Version
System Requirements
Operating Systems
The latest version of the system software update is compatible with the following Macintosh versions:
  • macOS 10.14, 10.15, 11
Computer Hardware
The latest version of the system software update is compatible with the following hardware:
  • Mac with an Intel processor (Mac with Apple silicon is not supported)
  • Hard drive space: 600 MB or more
  • RAM: 600 MB or more
Other Hardware
  • Power source for the device.
    Fully charged rechargeable battery pack NP-FZ100.
    NOTE: The update can only be performed when the battery power level is  (three bars) or more. We recommend that you use a fully charged battery. Detach the vertical grip before updating system software.
  • USB Type-C cable supplied with the camera.
    NOTE: Update functionality is not guaranteed with any other USB cable.
Download & Install
Important notice
  • Please close all other application software before updating the system software.
  • Use a fully charged rechargeable battery pack (NP-FZ100).
  • Do not remove the battery during the update as the sudden loss of power may render the camera inoperable.
  • Remove the memory card from the camera before starting the update process.
  • The system software update will take approximately 20 minutes. Please do not allow your computer to go into Sleep mode during this time.
    If the computer does go into Sleep mode and the update is interrupted, the entire update process will need to be restarted.
  • Do not open About This System Software Updater in the System Software Updater menu as this may cause the Updater software to crash.
  • Do not connect the camera to other any other devices except your computer.
  • Do not connect the camera and computer yet.
  • Ensure that your computer is connected to the Internet.
  • Following the instructions in the System Software Updater window, on the camera, select Menu → Setup3 → USB Connection and check if Mass Storage has been selected. If a mode other than Mass Storage is selected, please select Mass Storage.
How to download the Sony Camera Driver:
  1. Visit the Sony Camera Driver download page.
  2. Click the Download button.
  3. After reading the disclaimer, click Download.
    NOTE: The Camera_Driver_2102a.dmg file will start downloading.
  4. Save the file to the desktop of your computer (recommended).
    File Size:130KB (129 582 byte)
How to download the Updater:
  1. After reading the disclaimer, click Download.
  2. The Update_ILCE9M2V3.00.dmg file will start downloading.
  3. Save the file to the desktop of your computer (recommended).
    File Size:328MB (328 014 840 bytes)
Step 1: How to Install the Sony Camera Driver
  1. Close all programs currently running on your computer.
  2. Double-click the Camera_Driver_2102a.dmg file you downloaded. Do not connect the camera at this point.
    NOTE: If you have connected the camera to a computer, disconnect it before following the procedure.
  3. The Sony Camera Driver Installer is expanded.
  4. Double-click the SonyCameraDriver.pkg icon.
  5. The installer screen opens. Proceed as instructed.
  6. You are asked to allow the system to start installation. Type the password for the administrative account.
    NOTES:
    • If the operating system displays the System Extension Blocked dialog message (the actual message will vary depending on the operating system version), click the Open Security Preferences button. The macOS Security & Privacy screen opens.
    • If the operating system does not display the System Extension Blocked dialog message, go to Step 2: Start the Updater onward.
  7. In the Security & Privacy screen, open the General tab and then click the key icon. When prompted to enter the password, type the password you used when logging in with the administrator account and then click the Unlock button.
  8. Click the Allow button to allow the system to start loading the system software from Sony Imaging Products & Solutions Inc.
  9. After clicking the Allow button, if you are asked to restart, restart the computer and return to the beginning of the update procedure.
  10. If the Security and Privacy screens does not disappear, please close the window.
  1. Double-click the Update_ILCE9M2V3.00.dmg file you downloaded. Do not connect the camera at this point.
  2. Update_ILCE9M2V3.00 is expanded.
  3. Double-click the SystemSoftwareUpdate icon.
  4. The message prompts you to allow the application to make changes. Type the password for the administrative account.
  5. The System Software Updater will start.
    NOTES:
    • If the system is not ready to start updating, an error message appears. Take appropriate action according to the message and then double-click SystemSoftwareUpdater again.
    • If the message You need to restart your computer. appears, restart the computer and then double-click SystemSoftwareUpdater again.
    • If the message You need to install Sony Camera Driver appears, perform the procedure described in Step 1: How to Install the Sony Camera Driver, then double-click SystemSoftwareUpdater again.
    • If the message Check the Security & Privacy setting. appears, perform steps 7 and 8 in the Step 1: How to Install the Sony Camera Driver section, then restart the computer and double-click SystemSoftwareUpdater again.
  6. Turn on the camera and connect the camera to the computer with the supplied USB cable, USB Mode appears on the LCD screen of the camera.
  7. Click Next. The current version number and updated version number appear on the lower left side of the screen.
    NOTE: If the computer cannot find the device, the message Could not find the camera for this update is displayed on the computer screen. Please try the following:
    • Disconnect the USB cable and connect it again.
    • If the computer has multiple USB terminals, try with the other terminals.
      IMPORTANT: Never turn off the camera or disconnect the USB cable while updating.
  8. After confirming that the current software version is 2.00 or before, click Next. If the current system software version is 3.00, the update is not required. In this case, disconnect the camera from the computer and click Finish, turn off the camera, remove the battery pack, reinsert the battery and turn the camera back on.
    Update is required
    Update is not required
  9. The camera will automatically be reset.
    NOTE: The Loading icon may not be displayed depending on the OS version that you are using.
  10. Start the update. After automatically resetting, the update will begin and a progress bar will appear. The update will take approximately 20 minutes to complete.
  11. When the update is complete, the camera will automatically restart.
  12. When the LCD screen appears again, click Finish and disconnect the USB cable.
    NOTE: After restarting, a data recovery warning is sometimes displayed. This is normal. Please wait until this warning disappears.
Step 3: Confirm that the system software version of your device.
Updated System Software Version
Questions & Answers
The update does not complete
If the monitor remains black for more than 24 minutes, follow these steps to troubleshoot the issue:
  1. Disconnect the USB cable from the computer.
  2. Remove the battery and AC adapter from the camera, leave it for a few minutes, then insert the battery again or connect the AC adapter.
  3. Restart the computer.
  4. Turn on the camera and perform the installation process again.
