Applicable Model
This information is for the following model(s):
  • ILCE-7RM5
Required Downloads
Read this section before downloading the file.
Precautions when updating from Ver. 1.00
  • For customers who have been using the Imaging Edge Mobile app:
    • Updated cameras will no longer be able to connect to the Imaging Edge Mobile app. After updating the camera, install the Creators' App.
    • Please make sure the Imaging Edge Mobile app is the latest version (Ver.7.7.2 or later) in order to pair the camera with the Creators' App.
    • For instructions on installing and connecting the Creators' App, please refer to Migrating from Imaging Edge Mobile app to Creators' App.
  • If you use the Wireless Remote Commander/Shooting grip (GP-VPT2BT, RMT-P1BT), delete it from the Bluetooth Settings on the camera menu. Then pair the camera with the Wireless Remote Commander/Shooting grip again.
About This Download
What to Keep in Mind Before Performing the Update
  • You can download the software update using the Creators' App available in the App Store and Google Play.
How to Save Your Settings Before Updating
When updating to this software version, the following settings will be unregistered or reset to their default values:
  • Settings for Monitor Flip Direction, Network Streaming, Cloud Connection, and Access Authen.
  • Switch Focus Area and Send to Smartphone registered to Custom Key
  • Version, Touch Sensitivity, and Touch Panel settings registered in My Menu
Note: Even if you previously saved your settings using features such as Save/Load Settings, these settings will not be carried over to cameras with Ver. 4.00 or later. We recommend writing down your settings in advance as needed.
Benefits and Improvements
Shooting and Playback Functions
  • Adapts the display layout of shooting information for both horizontal and vertical viewing
  • Adds Spot: XL under Spot in the Focus Area menu
  • Adds Custom 1, Custom 2, and Custom 3 under Custom in the Focus Area menu
  • Adds Tracking: Spot XL, Tracking: Custom 1, Tracking: Custom 2, and Tracking: Custom 3 under Tracking in the Focus Area menu
  • Adds the Golden Ratio Grid option to the Grid Line Type setting menu
  • Adds the option to enlarge the menu screen display
  • Allows you to add OK/NG/KEEP flags to clips during or after movie recording
  • Allows the remaining capacity of both storage devices to be displayed during movie recording when using Simult. or Auto Switch Media (Relay Recording)
  • Adds support for the Relay Playback function
  • Adds a function that allows you to narrow down played-back images using multiple filters (e.g. Rating)
  • Allows Custom Key settings to be assigned to the AF-ON, AEL, and Delete buttons during playback
  • Adds support for importing/switching multiple IPTC Presets
  • Supports the Write Digital Signature function for still images and movies as part of Sony's Camera Authenticity Solution
    • The timing for the provision of licenses (paid) to customers other than certain media outlets is yet to be determined.
    • Services may not be available in some countries or regions. For more information, please visit the Authenticity Catalog Page.
  • Supports Scan and Tag, Photo Cropping, and Volume Photography Commands under the Volume Photography License
    • Installation of a paid license is required for use.
FTP Transfer and Network Functions
  • Allows scheduling of FTP transfers while writing data to the camera's storage media
  • Allows you to automatically schedule FTP transfers of protected movies and still images
  • Allows you to automatically protect movies/still images transferred via FTP transfer
  • Allows you to transfer specific images with priority during FTP transfer
  • Supports the following Monitor & Control app function:
    • Focus map display
      Note: The latest version of the Monitor & Control app is necessary. The app may not be available in some countries or regions.
Others
  • No longer supports the Security (IPsec) functionality
    Note: Please enable and use Access Authen. as it provides more secure protection.
  • No longer supports the WPA and WEP functionalities
    Note: You will no longer be able to select WPA or WEP when connecting to Wi-Fi. Please use the more secure WPA2 or WPA3 moving forward.
  • Fixes an issue where the focus may not reach infinity during Focus Bracketing
  • Fixes an issue where color reproduction may vary even when the white balance is fixed during exposure bracket shooting in lossless compressed RAW
  • Improves the operational stability of the camera
Note: Please refer to the Help Guide for details on all updated functions.
Previous Benefits and Improvements
File Info
  • Name: BODYDATA.DAT
  • Version: 4.00
  • Size: 754 525 608 bytes
  • Release Date: 26-11-2025
Preparation
How to Update Your Sony Camera With a Memory Card (SD or CFexpress)
Check the System Software Version
Follow the instructions below to check the system software version.
    1. Select Menu → Setup → Setup Option → Version → Body.
    2. The system software version will be displayed.
    Note: If the Date/Time setting screen appears when you turn on your camera, be sure to set the date and/or time to the correct values.
    Saving the System Software Data to a Memory Card
    IMPORTANT: Make sure there is only one BODYDATA.DAT file on the memory card.
      1. Click the Download button.
      2. After reading the disclaimer, click Download.
      3. Save the file to your computer.
      4. Insert the formatted memory card into the computer.
      5. Save the BODYDATA.DAT file in the root directory of the memory card. Do not change the file name.
      Notes:
      • Please format the memory card in advance using this camera.
      • Before formatting, copy the data to a computer or other device.
        Once you format the memory card, all the data recorded on the memory card will be deleted and cannot be restored.
      • Please refer to the instruction manual of the camera for compatible memory cards.
      Other Hardware
      • Power source for the camera: Use a fully charged rechargeable battery pack (NP-FZ100).
        Note: The update can only be performed when the battery power level is at least three bars or 51%. We recommend you use a fully charged battery.
      • Detach the vertical grip from the camera before updating the system software.
      Updating the System Software Version
      Important Notice
      • Use a fully charged rechargeable battery pack (NP-FZ100).
      • Do not remove the battery during the update as the sudden loss of power may render the camera inoperable.
      • It may not be possible to update if the camera temperature is high. Please wait to update until after the temperature drops.
      Step 1: Update the System Software
      1. Insert the memory card that contains the saved system software data into slot 1 of the camera. For models with two slots, make sure to insert the memory card into slot 1. Only slot 1 will recognize the system software data.
      2. Select Menu → Setup → Setup Option → Version → Body.
      3. Select Software Update.
      4. Select Execute on the system software update confirmation screen. The software update will start.
        On-screen message:
        • Update? X.XX → Y.YY
          • X.XX: Current version number
          • Y.YY: Newest version number
        Notes:
        • Do not remove the battery or memory card during the update.
        • After confirming the details, you may click Execute.
        • Please scroll down the screen as necessary to view the full text.
      5. When the system software update starts, a black screen will appear and the access lamp will flash 1 time → 3 times → 5 times depending on the progress of the update. The update will take approximately 6 minutes to complete.
        Location of the Access lamp: It's on the bottom right of Rear side.
        Notes:
        • If the system software data copy is incorrect, the message “The target model for the update file is incorrect” will be displayed on the camera monitor.
        • If the access lamp repeats 5 long blinks (0.5-second cycle) and 6 short blinks (0.25-second cycle), or 7 long blinks (0.5-second cycle) and 7 short blinks (0.25-second cycle), the system software may have been incorrectly copied to the memory card.
          • In this case, remove the battery and memory card from the camera, prepare another memory card, and then start over from the Saving the System Software Data to a Memory Card section of this article.
      6. When the update is complete, the camera will automatically restart. After restarting, press OK on the “Body update complete” screen.
      Step 2: Confirm the System Software Version of Your Camera
        The update was successful if the screen shows Ver. 4.00.
