Applicable Model
This information is for the following model(s):
  • ILCE-1
Required Downloads
  • Updates should be installed in chronological order!
    • For Ver. 1.32 or earlier:
      1. Update to Ver. 1.35 (an interim version included in this software package) by using the update program 01_Update_ILCE1V135.app.
      2. After updating to Ver. 1.35, use the update program 02_Update_ILCE1V201.app to update from Ver. 1.35 to Ver. 2.01.
    If you have already updated the software version to Ver. 1.35 or Ver. 2.00, please use 02_Update_ILCE1V201.app.
  • To install this update, you need to download the Sony Camera Driver first. For details, read the How to download the Sony Camera Driver section in this article.
About this download
Update overview
Fixes an issue where the camera may not be able to connect to the network after installing the system software update for Ver. 2.00. We apologize for the inconvenience.
This update also includes the benefits from the Ver. 2.00 update.
Things to keep in mind before performing the update
  • Make a note of your settings (in case of updating from Ver. 1.32 or lower):
    • After updating to this version, the camera settings will reset to the default values.
    • Since this update adds functions and major specification changes, the camera settings will be initialized as part of the update process.
    • We recommend you make a note of all the camera settings before proceeding.
    • Even if you have saved the settings using the various save features available (such as Save/Load settings and Save/Load FTP settings) the settings before Ver. 1.32 cannot be applied after the update.
  • Switching from Imaging Edge Mobile to Creators' App:
    • If you’re using the Imaging Edge Mobile app, please be aware that updated cameras will no longer be able to connect to this app. After updating your camera, install the Creators' App.
      • Please make sure the Imaging Edge Mobile app is Ver. 7.7.2 or later in order to pair the camera with the Creators' App.
    • If the Imaging Edge Mobile app is not Ver. 7.7.2 or later, update it before trying to pair the camera with the Creators' App.
    Note: For instructions on installing and connecting the camera to the Creators' App, please refer to Migrating from Imaging Edge Mobile app to Creators' App.
    Additionally, the NFC one-touch connection function used for the camera version 1.32 or earlier will no longer be available.
Benefits and Improvements
  • Support for mobile applications:
    • Adds support for the Creators' App
      Notes:
      • The new Creators' App mobile application replaces the Imaging Edge Mobile app. The Creators' App allows you to transfer images from the camera to your smartphone, shoot remotely, and use other various functions.
      • Availability depends on the country and region.
    • Adds support for the Monitor & Control app
      Notes:
      • The Monitor & Control app connects wirelessly to a camera and enables video monitoring and remote operation using a smartphone or tablet.
  • Shooting & playback functions:
    • Adds support for the Relay Playback function
    • Adds support for Breathing Compensation
      Note: For compatible lens information, please refer to this support page.
    • Adds the Sync Release function that releases the shutters of multiple sub-cameras in conjunction with the main camera’s shutter timing
      Note: Remote Camera Tool Ver. 4.1.00 is required to activate this function.
    • Adds a function that displays the focus frame on the Remote Camera Tool screen when the monitor and viewfinder are turned off
    • Adds support for Image Stabilization with Body-Lens Coordinated control. For compatible lens information, please refer to this support page.
    • Adds a function that allows you to narrow down the images to be played back using multiple filtering conditions, such as FTP transfer status
      (FTP = File Transfer Protocol)
    • The maximum number of images that can be recorded in one folder has been increased to 9,999
    • Allows Timecode input with the Multi/Micro USB Terminal. You can set the timecode with the source equipment
      Note: A dedicated adapter cable, which is sold separately, is required to connect to the timecode source equipment.
    • Adds support for importing/switching multiple IPTC Presets
      (IPTC = International Press Telecommunications Council)
    • Adds support for C2PA format (The license availability date is undecided)
      (C2PA = Coalition for Content Provenance and Authenticity)
    • Adds support for Custom Grid Line
      Notes:
      • Custom Grid Line is available as a paid license.
  • FTP transfer & network functions:
    • Allows you to upload camera images directly to the Creators’ Cloud app
      Notes:
      • Creators' App Ver. 2.3.1 or later is necessary. Settings must be adjusted in the Creators' App in advance. For more information, please visit the Creators' App support website.
    • You can now automatically schedule FTP transfer of protected movies and still images
    • Movies/still images transferred via FTP transfer can now be automatically protected
    • You can now transfer specific images with priority during FTP transfer
    • Adds support for USB streaming
      Note: When connecting to a device with a USB Type-C® port, please use a commercially available USB cable or a conversion adapter.
    • Adds support for SFTP
      (SFTP = Secure File Transfer Protocol)
    • Wireless LAN security now supports WPA3-SAE
    • Improves remote shooting and image transfer security when using the Creators' App and Imaging Edge Desktop software
      Note: Please update the Imaging Edge Desktop software to the latest version (Ver. 3.7.0 or later).
  • Others:
    • Fixes an issue where the camera may not be able to connect to the network
    • Fixes an issue where images may not be transferred properly during FTP transfer
    • Fixes an issue where the folder name setting for still images may switch from the set value to the default value (MSDCF) when the battery is removed
    • Fixes an issue where the timecode wasn’t always retained after a power restart
    • Improves the exposure stability when using extended ISO during movie recordings
    • Improves the operational stability of the camera
Notes:
  • Please refer to the Help Guide for details on all updated functions.
  • This update is only available for Windows and macOS. A memory card version is not provided.
Previous Benefits and Improvements
File Info
  • Name: Update_ILCE1V201.dmg
  • Version: 2.01
  • Size: 1.54 GB (1 538 554 073 bytes)
  • Release Date: 24-04-2024
Preparation
How To: Update Your Sony Camera Firmware
Check the system software version
Follow the instructions below to check the system software version. If the system software version is Ver. 2.00 or earlier, the update is required. If you are using Ver. 2.01, you do not need to update.
Notes:
  • If the Date/Time setting screen appears when you turn on your camera, be sure to set the date and time to the correct values.
  • If the Language setting screen appears when you turn on the camera, be sure to set the language.
  1. On the camera, select Menu → Setup → Setup Option → Version.
  2. The system software version will be displayed.
The downloaded package consists of the following:
In the folder Update_ILCE1V201, there are files 01_Update_ILCE1V135 and 02_Update_ILCE1V201.
Notes:
  • When updating from Ver. 1.32 or earlier, first update to an interim version using the update program 01_Update_ILCE1V135.app, then use the update program 02_Update_ILCE1V201.app to update to Ver. 2.01.
  • If you have already updated the software version to Ver. 1.35 or Ver. 2.00, please start from Step 3.
  • The interim version will be Ver. 1.35.
System Requirements
Operating Systems
The latest version of the system software update is compatible with the following Macintosh operating system versions:
  • macOS 12
  • macOS 13
  • macOS 14
Computer Hardware
The latest version of the system software update is compatible with the following hardware:
  • Hard drive space: 1.6 GB or more
  • RAM: 1.6 GB or more
Other Hardware
  • Power source for the camera: Use a fully charged rechargeable battery pack NP-FZ100.
    Note: The update can only be performed when the battery power level is three bars (or more) or above 51%. We recommend that you use a fully charged battery. Detach the vertical grip before updating the system software.
  • Use the USB cable supplied with the camera.
    Note: Update functionality is not guaranteed with any other USB cable.
Download & Install
Important Notice
  • Close all other application software before updating the system software.
  • Use a fully charged rechargeable battery pack (NP-FZ100).
  • Do not remove the battery during the update as the sudden loss of power may render the camera inoperable.
  • Remove the memory card from the camera before starting the update process.
  • The system software update will take approximately 30 minutes. Do not allow your computer to go into Sleep mode during this time.
    Note: If the computer does go into Sleep mode and the update is interrupted, the entire update process will need to be restarted.
  • Do not open the About This System Software Updater window in the System Software Updater menu as this may cause the software to crash.
  • Do not connect the camera to any other device except your computer.
  • Do not connect the camera and computer until instructed to do so.
  • Make sure your computer is connected to the internet.
  • Follow the instructions in the System Software Updater window:
    On the camera, select Menu → Setup → USB → USB Connection, and then check if Mass Storage has been selected. If a mode other than Mass Storage is selected, select Mass Storage.
  • On Mac computers with an Apple silicon (Apple M1) processor, you need to change the security policy. The About This Mac screen will show an item labeled Chip, followed by the name of the chip. Refer to the How to change the security policy on Mac computers with Apple silicon article. For Mac computers with an Intel processor, this step is not necessary.
How to download the Sony Camera Driver:
  1. Visit the Sony Camera Driver download page and download the driver:
  2. Click the Download button.
  3. After reading the disclaimer, click Download.
  4. Save the file to the desktop of your computer (recommended).
How to download the Updater:
  1. Click the Download button above.
  2. After reading the disclaimer, click Download.
    Note: The Update_ILCE1V201.dmg file will start downloading.
  3. Save the file to the desktop of your computer (recommended).
    Note: File Size: 1.54 GB (1 538 554 073 bytes)
Step 1: How to Install the Sony Camera Driver
  1. Close all programs currently running on your computer.
  2. Double-click the Camera_Driver_2110a.dmg file you downloaded. Do not connect the camera at this point.
    Note: If you have already connected the camera to your computer, disconnect it before following the procedure.
  3. The Sony Camera Driver Installer will expand.
  4. Double-click the SonyCameraDriver.pkg icon.
  5. The installer screen will open. Proceed as instructed.
    Read the Introduction displayed on the screen and press the [Continue] button at the bottom right of the screen to proceed.
  6. You will be prompted to allow the application to install new software. Type the password for the administrative account.
    Enter it in the Password field in the center of the screen, and press the [Install Software] button at the bottom  center of the screen.
    Notes:
    • If the operating system displays the System Extension Blocked dialog message (the actual message will vary depending on the operating system version), click the Open Security Preferences button. The macOS Security & Privacy screen will open.
    • If the operating system does not display the System Extension Blocked dialog message, go to Step 2 to continue.
  7. For macOS 12, open the General tab in the Security & Privacy screen and click on the key icon. When prompted to enter the password, type the password you used when logging in with the administrator account, and then click the Unlock button.
  8. Click the Allow button to allow the system to start loading the system software.
  9. For macOS 13 and macOS 14, go to System Settings and press the Allow button in the Privacy & Security menu If you cannot find the Allow button, try scrolling down the screen.
  10. After clicking the Allow button, if you are asked to restart, restart the computer and return to the beginning of the update procedure.
  11. If the Security & Privacy screen does not disappear, close the window.
Step 2: How to update Ver. 1.32 or earlier to the interim version of the software
If you are using Ver. 1.35 or Ver. 2.00, you do not need to update to an interim version.
  1. Double-click the Update_ILCE1V201.dmg file you downloaded. Do not connect the camera at this point.
  2. The Update_Update_ILCE1V201.dmg file will expand.
  3. Double-click the 01_Update_ILCE1V135 icon.
  4. The message will prompt you to allow the application to make changes. Type the password for the administrative account.
  5. The System Software Updater will start.
    Notes:
    • If the system is not ready to start updating, an error message will appear. Take appropriate action according to the message and then double-click 01_Update_ILCE1V135.app again.
    • If the message You need to restart your computer appears, restart the computer, then double-click 01_Update_ILCE1V135.app again.
    • If the message You need to install Sony Camera Driver appears, perform the procedure described in Step 1, then double-click 01_Update_ILCE1V135.app again.
    • If the message Check the Security & Privacy setting appears, perform steps 7, 8 and 9 in the Step 1 section, then restart the computer and double-click 01_Update_ILCE1V135.app again.
  6. Turn on the camera and connect the camera to the computer with the supplied USB cable. USB Mode will appear on the LCD screen of the camera.
  7. Click Next. The current version number and updated version number will appear on the lower left side of the screen.
    IMPORTANT: Never turn off the camera or disconnect the USB cable while updating.
    Note: If the computer cannot find the device, a Could not find the camera for this update message will display on the computer screen. Please try the following:
    • Disconnect the USB cable and connect it again.
    • If the computer has multiple USB terminals, try another terminal.
  8. After confirming that the current software version is Ver. 1.32 or earlier, click Next.
  9. If the current and post-update versions are not displayed and you are prompted to apply the next System Software Updater, please exit this update program and apply the update program 02_Update_ILCE1V201.app.
    • The update is required
      The [Current Version] on the lower left of the screen is showing 1.32 or earlier, and the [Version after the update] is showing 1.35.
    • Apply the next System Software Updater
      The only button on the screen is [Finish].
  10. The camera will reset automatically.
    Note: The Loading icon may not be displayed depending on the OS version you are using.
  11. Start the update. After automatically resetting, the update will begin and a progress bar will appear. The update will take approximately 30 minutes to complete.
  12. When the update is complete, the camera will automatically restart.
  13. When the LCD screen appears again, click Finish.
    Note: After restarting, a data recovery warning may be displayed. This is normal. Please wait until this warning disappears.
  14. This completes the application of the update program 01_Update_ILCE1V135.app. Go to Step 3. Keep the USB cable connected.
Step 3 Software update procedure from an interim version to Ver. 2.01
Notes:
  1. Check on the camera screen that the USB connection is Mass Storage. If Select USB Connection shown on the camera screen, select Mass Storage.
    Note: Select Menu → Setup → USB → USB Connection, and then check if Mass Storage has been selected. If a mode other than Mass Storage is selected, select Mass Storage.
  2. Double-click the Update_ILCE1V201.dmg file you downloaded. Update_ILCE1V201 will expand.
  3. Double-click the 02_Update_ILCE1V201.app icon.
  4. The System Software Updater will start.
  5. Click Next. The current version number and updated version number will appear on the lower left side of the screen.
    • Disconnect the USB cable and reconnect it.
  6. After confirming that the software version appears on the screen, click Next. If the current system software version is Ver. 2.01, the update is not required. In this case, follow the steps below:
    1. Disconnect the camera from the computer.
    2. Click Finish.
    3. Turn off the camera.
    4. Remove the battery pack.
    5. Reinsert the battery.
    6. Turn the camera back on.
      The [Current Version] on the lower left of the screen is showing 1.35 or earlier, and the [Version after the update] is showing 2.01.
    • If the following screen appears, disconnect the USB cable and check the version of the software. If the version of the software is Ver. 1.32 or earlier, please follow the steps in Step 2.
      Screen with the message [The firmware data is corrupted and the update process is aborted].
  7. The camera will reset automatically.
  8. Start the update. After automatically resetting the camera, the update will begin and a progress bar will appear. The update will take approximately 30 minutes to complete.
  9. When the update is complete, the camera will automatically restart. When the LCD screen appears again, click Finish, and then disconnect the USB cable.
Notes:
Step 4: Confirm the system software version of your device
Questions & Answers
The update does not finish
If the monitor remains black for more than 30 minutes, follow these steps to troubleshoot the issue:
  1. Disconnect the USB cable from the computer.
  2. Remove the battery and AC adaptor from the camera, leave it for a few minutes, then insert the battery again or connect the AC adaptor.
  3. Restart the computer.
  4. Turn on the camera and perform the installation process again.
After launching the System Software Updater, the screen for confirming the version does not appear and a Failed to update message is displayed.
If this happens, it is possible that you have updated your camera in the past using the System Software Update Helper driver and have not uninstalled that software:
  1. Download System Software Update Helper again and uninstall the driver using the uninstaller tool in the Uninstaller folder of the downloaded file.
  2. After uninstalling the System Software Update Helper driver, double-click the Update_ILCE1V201.dmg file to restart the update.
