Article ID : 00057548 / Last Modified : 20/05/2025Print
The edges of the image at the wide-angle side of the zoom appear to be distorted.
    As a characteristic of the wide-angle side of a zoom lens or a wide-angle prime lens, distortions appear around the edges of images.
    If the distortions bother you, it is recommended that you position the subject in the centre or set the focal length to the telephoto side while moving away from the subject if you are using a zoom lens.
    Example a shot at wide-angle
    Image with distortion around the edges
    Photographing from a position further away from the subject
    Image without distortion around the edges
