Article ID : 00338228 / Last Modified : 20/01/2026Print
    Difficult to attach or lock the Front Panel on MEX series Car Radio
    When you attach the faceplate to the front panel of the car radio, follow these steps:
    1. Insert the right side of the faceplate into the front panel.
    2. Push the Control dial on the faceplate until it locks into place on the front panel.
      Note: You may need to apply some force to get it to lock into place.
