Article ID : 00104489 / Last Modified : 07/01/2015Print
    How do I pair my smartphone and audio device together via Bluetooth?
    Follow these steps to test Bluetooth pairing on your smartphone:
    • After touching the audio device, complete the connection according to the instructions displayed on the smartphone screen.
    • Confirm that Bluetooth is enabled on the smartphone and that it's paired to the device.
    • Remove the paired devices and try connecting them again.
    • If the problem persists and you're unable to pair your audio device and smartphone together, you can connect them manually.
    • For further information on how to manually link devices via Bluetooth, refer to the instruction manual provided with your audio device.
