Article ID : 00408027 / Last Modified : 28/07/2026Print
    E-mount Lens Distortion Compensation for X-OCN Clips
    Camera [Distortion Comp.] settings are not applied to X-OCN clips recorded by the camera.
    Metadata required for distortion compensation is saved in clips captured with E-mount lenses made by Sony or license partners, enabling distortion compensation after shooting.*2, *3
    • Lenses for which [Distortion Comp.] is locked to [Auto]
      Using lens distortion compensation on Sony E-mount lenses with [Distortion Comp.] locked to [Auto] enables an optimal balance of performance, size, and weight.
      On the camera, [Distortion Comp.] is locked to [Auto], and [Off] cannot be selected.
      When recording X-OCN clips using these Sony E-mount lenses, use lens distortion compensation in Catalyst Browse, Catalyst Prepare, or Catalyst Prepare Plugin during editing.*1, *2, *3
      ILME-FX5 users can preview on the LCD screen how software-based distortion compensation will look as they shoot.*4
      Lenses for which [Distortion Comp.] is locked to [Auto] is available below.
    • Lenses for which [Distortion Comp.] can be set to [Auto] or [Off]
      For E-mount lenses made by Sony or license partners that are not listed, [Distortion Comp.] on the camera can be set to [Auto] or [Off].
      To apply distortion compensation, use this feature in Catalyst Browse, Catalyst Prepare, or Catalyst Prepare Plugin during editing.*1, *2, *3
      With [Distortion Comp.] set to [Auto], ILME-FX5 users can preview on the LCD screen how software-based distortion compensation will look as they shoot.*4
    • *1 Catalyst Prepare is not available in Mainland China.
    • *2 Distortion compensation is not available for X-OCN clips recorded in the S&Q or Interval Rec mode on BURANO cameras. Before use, check how any distortion will look.
    • *3 Distortion compensation is not available for X-OCN clips recorded on VENICE/VENICE 2 cameras. Before use, check how any distortion will look.
    • *4 On the ILME-FX5, a future update will enable clip previews with lens distortion compensation applied when using E-mount lenses made by Sony or license partners.
    For information on license partners, see the following page.
    E-mount License Partners
    For details, see the following page.
    FAQ on E-mount Lens Distortion Compensation for X-OCN Clips
    • FE 16-25mm F2.8 G
    • FE PZ 16-35mm F4 G
    • FE 20-70mm F4 G
    • FE 24-50mm F2.8 G
    • Vario-Tessar T* FE 24-70mm F4 ZA OSS
    • FE 24-105mm F4 G OSS
    • FE 24-240mm F3.5-6.3 OSS
    • FE 28-60mm F4-5.6
    • FE 28-70mm F3.5-5.6 OSS II
    • FE PZ 28-135mm F4 G OSS
    • FE 70-200mm F4 Macro G OSS II
    • FE 16mm F1.8 G
    • FE 24mm F2.8 G
    • FE 28mm F2
    • FE 40mm F2.5 G
    • FE 50mm F2.5 G
    • Sonnar T* FE 55mm F1.8 ZA
    • E PZ 10-20mm F4 G
    • E PZ 16-50mm F3.5-5.6 OSS II
    • E 16-55mm F2.8 G
    • E 18-50mm F4-5.6
    • E PZ 18-105mm F4 G OSS
    • E 18-135mm F3.5-5.6 OSS
    • E 70-350mm F4.5-6.3 G OSS
    • E 11mm F1.8
    • E 15mm F1.4 G
    Note: This list does not imply that certain lenses are more capable or higher-performance than others.
