Article ID : 00375614 / Last Modified : 05/01/2026Print
What should I do if the hood interferes with a third-party 86 mm filter on the SEL2870GM?
    Depending on the filter, it may not be possible to attach the hood. Choose a filter with a diameter of 86 mm and an outer diameter of 89.4 mm or less, as filters with an outer diameter over 89.4 mm may interfere with the hood. If using such filters, refrain from using the lens hood.
    Note: The outer diameter of the filter refers to the diameter including the filter frame.
