Article ID : 00405421 / Last Modified : 17/06/2026Print
    Is it possible to save/load settings using a memory card between identical camera models with different system software versions?
    Save/Load Settings is possible between identical camera models with the same system software version.
    However, depending on the content of past updates, it may not be possible to load settings files between different versions.
