Article ID : 00255861 / Last Modified : 08/06/2026Print
Which software supports playback and editing of XAVC HS files?
    A compatible application is needed in order to playback and edit movies in the XAVC HS format.
    We recommend using Catalyst Browse/Catalyst Prepare.
    If you opt for a different application, please contact the manufacturer for more information on compatibility.
