Article ID : 00142819 / Last Modified : 11/12/2017Print
    The projected video image is blurry or out of focus.
    This may occur if the focus is not adjusted properly or if the projector lens is dirty.
    • Focusing
      Adjust the focus manually. Move the focus lever until the projected video image appears sharp.
      NOTE: Move the camcorder to an optimal distance for projection: 1.6 ft. / 0.5 m or farther.
      [A] focus lever
    • Projector lens
      If the projector lens surface is soiled, use a soft cloth to wipe any dust or blemishes away from it.
