The resolution varies according to the lighting status of the lamp of the battery charger.
Check the status of the CHARGE (charge) lamp of the battery charger and resolve the issue.
| The lamp lights | The battery is being charged. Wait until the lamp goes out when the charging finishes. |
| The lamp goes out immediately after it lights. | Charging is complete. NOTE: If the lamp goes out right after charging has started, there is a possibility that the camera has been already charged. Check the battery remaining amount on the camera. |
| The lamp flashes | |
[B] If the Lamp lights up faster than 1 second
If the lamp doesn't light up and you are using an extension cord, directly attach the cable to a wall socket to check symptoms.
Also, check the bottom diagram for the direction the charger is to be attached.
NOTE: When using the commercially available battery charger (BC-TRX), change the selector switch according to your charging method.
- When charging the battery installed with the camera : BATTERY CHARGE
- When charging by connecting with the USB cable : USB POWER 5V 1500mA
