macOS Catalina(10.15) Compatibility Information for Application Software
We have checked the operation of the application softwares listed on this page.
IMPORTANT: Operation is not guaranteed for all computers.
| Application Software | Version | Applicable Product Categories | macOS Catalina (10.15) | Notes |
| Imaging Edge (Remote/Viewer/Edit) *64-bit only | 2.0.02 | Cyber-shot α (Alpha) | Under Evaluation | We have confirmed that some functions cannot be used when using this app on a PC upgraded to macOS 10.15. We are currently reviewing the situation to come up with a solution. |
| PlayMemories Home | - | Handycam Cyber-shot α (Alpha) Action Cam Bloggie / Webbie Digital Recording Binoculars | Not Support | |
| Action Cam Movie Creator | - | Action Cam | Not Support | |
| MVR studio | - | Music Video Recorder | Not Support | |
| IPTC Metadata Preset | 1.1.00 | Refer to the "Supported Devices." | Under Evaluation | |
| Remote Camera Tool | 2.1.00 | Refer to the "Supported Devices." | Under Evaluation | |
| PlayMemories Camera Apps | - | Cyber-shot α (Alpha) | Under Evaluation | Refer to the "Notice / Maintenance information" |
