Article ID : 00412436 / Last Modified : 28/09/2026Print
    macOS Tahoe (macOS 26) Compatibility Information for α (alpha) Digital Cameras
    Compatibility is verified for the following products:
    IMPORTANT: Performance is not guaranteed for all computers.
    α E-mount cameras
    • ILCE-1: Compatible
    • ILCE-1M2: Compatible
    • ILCE-7C: Compatible
    • ILCE-7CR: Compatible
    • ILCE-7CM2: Compatible
    • ILCE-7M4: Compatible
    • ILCE-7M5: Compatible *1
    • ILCE-7RM3A: Compatible *2
    • ILCE-7RM4: Compatible *2
    • ILCE-7RM4A: Compatible *2
    • ILCE-7RM5: Compatible
    • ILCE-7RM6: Compatible *1
    • ILCE-7SM3: Compatible
    • ILCE-9M2: Compatible *2
    • ILCE-9M3: Under Evaluation
    • ILCE-6100: Compatible *2
    • ILCE-6100A: Compatible *2
    • ILCE-6400: Compatible *2
    • ILCE-6400A: Compatible *2
    • ILCE-6600: Compatible *2
    • ILCE-6700: Compatible
    • *1 RAW file thumbnails may appear as generic icons. This occurs when you import images to your computer.
    • *2 AVCHD videos may not play on your computer if you import only a single AVCHD file — specifically, when that file is the only content on your camera.
    Interchangeable-lens vlog camera
    • ZV-E1: Compatible
    • ZV-E10: Compatible
    • ZV-E10M2: Compatible
