Article ID : 00155411 / Last Modified : 16/01/2026Print
    The Blu-ray Disc Player does not automatically connect to a Bluetooth device
    If the Blu-ray Disc Player does not automatically connect to a Bluetooth® device, check the following:
    Important: Turn off any other Bluetooth device to avoid connection interference.
    • Verify that the Bluetooth function of the Blu-ray Disc Player is enabled.
      1. On the supplied IR remote control, press the HOME button.
      2. Select Setup.
      3. Select Bluetooth Settings.
      4. Select Bluetooth Mode.
    • Verify that the Bluetooth device is registered on the Blu-ray Disc Player.
      2. Select Setup.
      4. Check the contents of the Device List.
    • If the Bluetooth device is not in the list, try pairing it again.
    NOTE: If the player already has a paired device, delete the pairing information from the device list and disconnect  the device before retrying the connection. Once the connection registration information has been erased. Perform the connection operation again.
