Article ID : 00275024 / Last Modified : 20/01/2026Print
How to change the volume, pause, or skip content with the neckband speaker when connected to a TV via a transmitter
    To change the Volume
    Use the volume button on the neckband speaker or headphones to control the volume. The TV remote control cannot be used to adjust the volume.
    Note: You cannot adjust the volume with headphones that do not have a volume adjustment function.
    To play, pause or skip content
    Play, pause or skip content using your TV remote control. The headphones or neckband speaker cannot be used to play, pause or skip content on the TV.
