NOTE: For troubleshooting and operation information other than sound/audio, see the following article: Handy TV Speaker: Troubleshooting and How to use
Table of contents
There is no sound
Q1: Sound doesn't come out from the Handy TV speaker when the external devices are connected to the TV via the AV amp.
A1: Connect external devices to the TV directly. When external devices such as Blu-ray Disc player are connected to the TV via the AV amp, audio signals are not output from the AV amp to the TV.
Q2: Sound suddenly stopped playing.
A2: Sound may have stopped due to power shutting off by the Auto Shut OFF function. Press the SPEAKER power button on the Handy TV speaker to turn on the power.
NOTES:
- If the power is shut off by the Auto Shut OFF function, even if the SPEAKER power button is set to On, the power will turn off.
- For details on Auto Shut OFF, visit Auto Shut OFF function does not work.
Q3: After installing the Handy TV speaker, sound stopped coming out of the TV.
A3: Depending on the TV model, connecting the TV and Transmitter via Audio cable may cause the TV speakers to go mute. Make the connection via Optical audio cable to allow sound to come out of TV speakers and Handy TV speaker at the same time. If connection via Optical audio cable is not possible, you may be able to allow sound to come out of both speakers by changing your TV’s audio output settings. For details, refer to the instruction manual for the TV.
Q4: TV and Transmitter are connected via Optical audio cable, but no sound comes out of the Handy TV speaker.
A4: Check that Digital audio out is set to PCM. The following is an example of how to perform settings on some Sony TVs:
- Press the Home
button on the remote control.
- Select Settings.
- Select Sound in the TV category.
- Select Digital audio out, then set to PCM.
Volume/sound quality is unstable
Q1: When changing the TV volume, the Handy TV speaker volume changes at the same time.
A1: This situation occurs when the TV and Transmitter are connected via the Audio cable. To prevent this issue, connect via Optical audio cable.
If connection via the Optical audio cable is not possible, check the following.
For Sony Android TV models
When adjusting the TV’s headphone volume, sometimes it is only possible to adjust the Handy TV speaker. Check the following operation:
- Press the ACTION MENU button on the remote control while watching TV.
- Select Headphone volume.
- Press the Volume + or Volume - button to adjust the volume.
NOTE: When no sound comes out of the TV speaker and Handy TV speaker at the same time, check the following. Also, depending on the model of TV, it may not be possible to play sound from the TV speaker and Handy TV speaker at the same time.
- Press the Home button on the remote control.
- Select Settings.
- For Android OS6(M):
- Select Headphone speaker link, then select Speakers on.
- For Android OS7(N):
- Select Audio to both TV speakers & other devices, then set to On.
For Sony TVs not listed above/non-Sony TVs
If you can fix the headphone output settings, change the settings. For details, refer to the instruction manual for the TV.
Q2: I sometimes hear noise.
A2: If you hear noise from the Handy TV speaker, the following may cause the issue.
- Mobile phones or other devices that transmit radio waves
Noise can sometimes be caused by radio waves generated just before and after mobile phone use and when sending and receiving phone calls. Use these kinds of devices away from the Handy TV speaker. - Cable not properly connected
Check that the Audio cable is firmly inserted into the TV’s headphone terminal.
NOTE: When the TV’s headphone terminal is dirty, it may cause a poor connection. If this is the case, remove and reinsert the Audio cable several times or clean it with a cotton swab or something similar. - Effect of silence
When the Handy TV speaker is ON and in silent mode, you may hear noise (e.g. whooshing). Noise is connected to the volume, so if it bothers you, lower the volume.
Q3: Sound sometimes cuts out.
A3: When the Handy TV speaker is close to microwave ovens, wireless LAN routers, Wi-Fi-equipped devices and other wireless devices that use 2.4 GHz band frequency, they may cause sound to cut out. If the sound cuts out frequently, turn wireless devices off beforehand or use the Handy TV speaker as far away from such devices as possible.
Conditions and situations in which may be caused by wireless device interference:
- If the sound cuts out for less than 1 sec. continuously or several times over a short period, it may be the result of wireless device interference.
- If the sound cuts out for longer than 1 sec., it may result from microwave oven interference.
- If there is a smartphone or tablet nearby, it may be transmitting Wi-Fi signals even if the screen is off, so it may cause interference.
NOTE: If TV and Transmitter are connected via Optical audio cable, sound may cut out if the cable is not properly connected. Firmly insert the cable into both the TV and Transmitter until you hear a click.
What is the AUTO VOLUME function?
Q1: What is the difference between Weak and Strong on AUTO VOLUME function?
A1: When the surrounding sound becomes too loud, AUTO VOLUME automatically increases the volume of the Handy TV speaker. If it is set to Strong, the volume increases more than if it is set to Weak.
