Article ID : 00376874 / Last Modified : 25/01/2026Print
LinkBuds Clip: The earbuds won't turn off when removed, or the battery life is short even when fully charged
    If you experience any power or battery issues with your LinkBuds Clip earbuds, check the following:
    • The LinkBuds Clip does not have an IR sensor that detects the wearing condition, so the power does not turn off automatically when the earbuds are removed.
    • Make sure to store the earbuds in the charging case after use; do not place them on the table or put them in your pocket.
    • Leaving the charging case lid open will reduce the battery life of the charging case, so make sure to close the lid.
    Related Article
    If you feel the battery life is short, refer to this article: The battery life is short.
