Article ID : 00281816 / Last Modified : 04/12/2024Print
    How to replace ear fitting supporters on the LinkBuds (WF-L900)
    The LinkBuds fall out or are uncomfortable or painful.
    If you don't wear the LinkBuds properly or the ear fitting supporters aren't suitable for your ears, the tap detection function, Bluetooth pairing, or sound quality can be affected The headphones may also fall out or feel uncomfortable during use.
    Medium-sized (M) ear fitting supporters are attached to the LinkBuds at the time of purchase. If the fitting supporters are too big or too small, select a different fitting supporter to help the LinkBuds fit better and feel more comfortable. We recommend starting with the larger sizes and working your way down to the smaller sizes until you find the best fit.
    Note:  The best fitting supporter may be different for each ear.
    Watch this video or follow the instructions to replace the fitting supporters.
    Steps to replace the ear fitting supporters
    1. Gently raise the fitting supporter and remove it from one side of the LinkBuds.
      Note: Be careful not to pull the fitting supporter forcibly.
    2. Select a different size fitting supporter and align the protruding part of the LinkBud with the cutout on the fitting supporter (A). Make sure to insert the fitting supporter completely.
    3. After attaching the fitting supporter, check that there is no movement on the LinkBuds (shake your head back and forth).
      Note: If the LinkBuds fall off or move in your ears when you shake your head, select a different size.
    4. Repeat the procedure for the other side.
