Article ID : 00266107 / Last Modified : 13/01/2026Print
How to reset your home audio system to factory settings
    The steps to reset your home audio system to the default settings vary depending on your model.
    Click or tap the series and model name below to see the full reset procedure. If your audio system isn't listed, check the supplied product manual or search for it on the Sony support website.
    Hint: The reset procedure can be found in the Troubleshooting section of the Help GuideOperating Instructions, or Reference Guide.
    Resetting your home audio system
    Notes:
    • Use the buttons on the audio system to perform the steps below.
    • All user-configured settings (e.g. preset radio stations, pairing registration information, clock) are reset to the default settings and will need to be re-configured.
    • If you dispose of the audio system or give it to another person, reset it for security reasons.
