Article ID : 00149895 / Last Modified : 16/01/2026Print
    When using an Xperia smartphone running Android 5.x or later via the USB-B port, the device is never recognised when the input is switched to USB-B.
    Connection settings must be performed on the Xperia every time the input is switched to USB-B.
    Due to the restrictions on Android 5.x or later, connection settings must always be performed on the Xperia before selecting USB-B and playing back music.
    Perform the following connection settings on the Xperia, while it is connected to the USB-B port.
    1. Select Settings.
    2. Select Xperia Connectivity.
    3. Select USB Connectivity.
    4. Select Detect USB device.
