How to reset your home audio system to factory settings
The steps to reset your home audio system to the default settings vary depending on your model.
Click or tap the series and model name below to see the full reset procedure. If your audio system isn't listed, check the supplied product manual or search for it on the Sony support website.
Hint: The reset procedure can be found in the Troubleshooting section of the Help Guide, Operating Instructions, or Reference Guide.
Resetting your home audio system
Notes:
- Use the buttons on the audio system to perform the steps below.
- All user-configured settings (e.g. preset radio stations, pairing registration information, clock) are reset to the default settings and will need to be re-configured.
- If you dispose of the audio system or give it to another person, reset it for security reasons.
CMT Series
Select your model below:
- Disconnect and reconnect the system's AC power cord (mains lead).
- Press the
(ON / STANDBY) button to turn on the system.
- At the same time, press the
(ON / STANDBY), VOL+ (VOLUME plus), and
(STOP) / CANCEL buttons to reset the system.
- Using a ballpoint pen or other pointed object, press the RESET button located at the bottom of the system.
- Press the
(STOP), DIMMER, and
(ON / STANDBY) buttons to reset the system.
- Press the
(STOP), DISPLAY, and
(ON / STANDBY) buttons until "RESET" appears on the display.
Note: All user-configured settings, except for the DVD settings, will be reset.
- Press the
(STOP),
(ON / STANDBY), and DSGX buttons to reset the system.
- Press the
(STOP),
(REWIND), and
- Press the power button to turn on the system.
- At the same time, press and hold the DISPLAY, TUNER / BAND, and FUNCTION buttons until “COLD RESET” appears on the display.
Note: You can't reset the system to factory settings in Power Saving Mode.
- Press the
(STOP), ENTER / START, and
CMT-SBT20 / CMT-SBT20B / CMT-SBT40D / CMT-X3CD
- Press the
- At the same time, press and hold the FUNCTION and
(EJECT) buttons until "RESET" appears on the display.
- Disconnect the system's AC power cord (mains lead) and confirm that the STANDBY indicator on the front of the device is not lit.
- Reconnect the power cord and press the
Model not listed? Check the supplied product manual or search for it on the Sony Support website.
GTK Series
- Press the
- While holding down the
(STOP) button, press and hold the FUNCTION button for about 3 seconds to reset the system.
PAIRING and VOLUME – (minus) buttons for more than 5 seconds to reset the system.
Note: The user-configured settings will reset after the (POWER),
(BLUETOOTH), and AUDIO IN indicators on the system flash for more than 3 seconds.
- Press the
(POWER) button to turn on the system.
(BLUETOOTH), USB, and AUDIO IN indicators on the system flash twice.
- At the same time, press and hold the FUNCTION and VOLUME – (minus) buttons for more than 5 seconds to reset the system.
Note: The user-configured settings will reset after all the indicators on the system flash for more than 3 seconds.
- Press the
- At the same time, press and hold the FUNCTION/
PAIRING and – (VOLUME minus) buttons for more than 5 seconds to reset the system.
MHC Series
(STOP), ENTER, and
(ON / STANDBY) buttons.
- Press the
MHC-EC55 / MHC-EC77 / MHC-GX99
- Press the
- At the same time, press the PLAY MODE, FUNCTION, and
MHC-EC69 / MHC-EC69T / MHC-EC79 / MHC-EC79T / MHC-EC99 / MHC-EC99T
- Press the
(STOP), CD, and
MHC-GT111 / MHC-GT111Z / MHC-GT222 / MHC-GT44 / MHC-GT555
- Press the
(STOP), ENTER, and
(ON / STANDBY) buttons until “COLD RESET” appears on the display.
- Press the
- At the same time, press and hold the ENTER and TUNING+ /
(FAST FORWARD) buttons for about 3 seconds until “RESET” appears on the display.
- Press the
After the reset completes, the system automatically reboots. Press the
(POWER) button to turn the system back on.
All user-configured settings, except for certain setup menu settings, will be reset.
MHC-GT7DW / MHC-V77DW / MHC-V77W
- Press the
- Press OPTIONS.
- Press the
(UP/DOWN ARROW) button repeatedly to select “SYSTEM”, then press
- Press the
(UP/DOWN ARROW) button repeatedly to select “RESET”, then press
- Press the
(UP/DOWN ARROW) button repeatedly to select “YES”, then press
MHC-GTX888 / MHC-GTX787 / MHC-GTX777
- Press the
(STOP), DELAY, and
MHC-GZX33D / MHC-GZX55D / MHC-GZX88D
- Press the
(STOP) and LED COLOR buttons for about 3 seconds until “RESET” appears on the display.
(STOP), ENTER, and
- Press the
- While holding down the DIGITAL button, press the DISPLAY button.
- Press the
- Press the
- At the same time, press and hold the GUITAR and MEGA BASS buttons for about 3 seconds until “RESET” appears on the display.
Notes:
- For MHC-V43D / MHC-V73D: All user-configured settings will reset after all the indicators on the system flash for more than 3 seconds.
- After the reset completes, the system automatically reboots. Press the
(STOP) and
(FOLDER) buttons until "RESET" appears on the display.
Press the
At the same time, press and hold the FIESTA and GUITAR buttons for about 3 seconds until "RESET" appears on the display.
Notes:
- The user-configured settings will reset after all the indicators on the system flash for more than 3 seconds.
- Press the
(STOP) and BASS BAZUCA buttons for about 3 seconds until "RESET" appears on the display.
SHAKE Series
- Press the
(STOP) and LED COLOR buttons for about 3 seconds until "RESET" appears on the display.
SHAKE-X10 / SHAKE-X10D / SHAKE-X30D / SHAKE-X70D
- Press the
- At the same time, press and hold the DJ OFF and
(FAST FORWARD) buttons for about 3 seconds until "RESET" appears on the display.
Notes:
- All user-configured settings, except for some setup menu settings, will be reset.
SHAKE-X1D / SHAKE-X3D / SHAKE-X7D
- Press the
- At the same time, press and hold the DJ OFF and TUNING + buttons for about 3 seconds until "RESET" appears on the display.
Note for the SHAKE-X1D: All user-configured settings, except for the SETUP settings, will be reset.
Other audio systems
CHC Series
- Press the
(STOP), DISPLAY, and CD 1 buttons.
- Press the
(ON / STANDBY) button again to turn the system back on.
- While holding down the DISPLAY and FUNCTION buttons, press the TAPE button.
DHC Series
- Using a ballpoint pen or other pointed object, press the RESET button located on the back of the system.
- At the same time, press and hold the NAME EDIT / CHARACTER, 1 / ALL, and UPPER DISPLAY buttons until "RESET OK!" appears on the display.
The system will turn off on its own. - Disconnect and reconnect the system's AC power cord (mains lead).
FST / RDH Series
FST-GTK11iP / FST-GTK33iP / RDH-GTK11iP / RDH-GTK33iP
- Press the
(PLAY / PAUSE) and
FST-GTK17iP / FST-GTK37iP / RDH-GTK17iP / RDH-GTK37iP
- Press the
(ON/STANDBY) button to turn on the system.
- While holding down the FUNCTION button, press and hold the
(ON / STANDBY) button for about 3 seconds until "RESET" appears on the display.
LBT Series
LBT-LX30 / LBT-LX5 / LBT-LX50 / LBT-LX6 / LBT-LX7 / LBT-LX8
(CLOCK) / CLOCK SET, ENTER, and
- The next steps will depend on your audio system:
- For LBT-XB3: At the same time, press the GROOVE, ENTER / NEXT, and DISC 1 buttons.
- For LBT-XB5 / LBT-XB6: At the same time, press the SPECTRUM ANALYZER, ENTER, and DISC 1 buttons.
- Press the
(STOP), DELAY, and
NAS Series
(STOP), ENTER, and
Please accept Youtube cookies to watch this video
Access your cookie preferences below and make sure to switch on the Youtube cookie under the 'Functional' section.
Related Articles
Register your product
Get access to all information, keep your product up to date and enjoy great deals
Sony Community
Visit our Community and share your experiences and solutions with other Sony customers
Contact support
Contact your Sony Support team
Repair, Warranty & Spare Parts
Book, track or maybe even avoid a repair
