Article ID : 00160208 / Last Modified : 27/08/2026Print
    Can I use Bluetooth audio devices with my Google TV or Android TV?
    If your Google TV™ or Android TV™ supports the Bluetooth Advanced Audio Distribution Profile (A2DP), you can connect Bluetooth audio devices such as headphones or speakers and enjoy TV sound through those devices. Check which TVs support A2DP or compatible Sony audio devices:
    Check if your TV supports A2DP
    You can check the applicable TV models on our support website by going to the Specifications section of your product page. If your model can use Bluetooth headphones, A2DP is displayed in the Bluetooth profile section.
    Notes:
    • We do not guarantee operation with all Bluetooth audio devices. Refer to the compatible model list for the devices that have been confirmed.
    • You can also check the applicable TV models by confirming whether A/V sync is available on the TV Settings menu. If A/V sync is available, your TV model supports A2DP and can use Bluetooth audio devices:
      • If your remote control has a Quick Settings (spanner or gear) button, press the Quick Settings button Select Settings Display & Sound Audio output Bluetooth device settings Check if A/V sync is available.
        Note: If Bluetooth device settings is not shown, skip this step.
      • If your remote control does not have a Quick Settings (spanner or gear) button, press the HOME button and Select Settings. The next steps will depend on your TV menu options:
        • Select Display & Sound Audio output Check if A/V sync is available.
        • Select Sound Check if A/V sync is in the item.
    Check the compatible model list
    Choose your TV series. The models in the list are ones where we have confirmed the Bluetooth connection operations.
    Notes:
    • Bluetooth devices supporting A2DP that are not included in the compatible model list may work with your TV. However, we do not guarantee the functionality, audio latency, influence from the surrounding environment, etc.
    • Some models in the list below are not available in some regions.
    Notes:
    • Make sure your TV and other audio devices have the latest software update. You can install the latest software update for your TV model or other Sony audio devices from the Sony Support website. For how to update your TV, refer to the How to perform a software update article.
    • Only one Bluetooth audio device can be connected to the TV at a time. It is possible to connect Bluetooth devices other than the Bluetooth audio device at the same time.
    • The codec used when transmitting the Bluetooth audio device is SBC (Sub-Band Coding). (LDAC, AAC, aptX, eSBC, etc. are not supported.)
    • Depending on the TV app used, or the Bluetooth audio device connected, some app operations performed from the Bluetooth audio device may not work. In such cases, use the TV remote control to operate the app.
    • When connecting a BRAVIA TV with Bluetooth devices using a multipoint connection, a temporary audio delay or decrease in the recognition rate of the remote control's microphone may occur.
    • If pairing with a Bluetooth audio device that supports LE Audio frequently fails, try disabling the LE Audio connection on the Bluetooth audio device. For instructions on how to change this setting, please refer to the Bluetooth audio device's instruction manual.
    Related articles:
