Applicable Model
This information is for the following model(s):
  • TA-AN1000
About This Download
Benefits and Improvements
  • Adds connection support for the optional BRAVIA Theatre Sub 8 subwoofer
  • Adds connection support for the optional BRAVIA Theatre Sub 9 subwoofer
  • Adds connection support for the optional BRAVIA Theatre Rear 9 rear speaker
    Note: Some models may not be available in certain countries or regions.
Previous Benefits and Improvements
File Info
  • Name: AN10STR-1_491.zip
  • Version: 1.491
  • Size: 621 MB (652 130 722 bytes)
  • Release Date: 31-03-2026
Preparation
Check the Firmware Version
Your firmware may already be up to date, especially if you have a new AV Receiver. If the version number is 1.491 or higher, you do not need to update.
If you're not sure, it's easy to check which version of firmware you have:
  1. Turn on your TV and make sure that it's tuned to the input your AV Receiver is connected to, so if the AV Receiver is connected to the HDMI2 socket, choose HDMI2 as the input.
  2. Turn on the AV Receiver.
  3. Press HOME on the remote control and wait until you see the HOME screen.
  4. On the home screen, select Setup → System Settings with the arrow keys on the remote control and then press ENTER.
  5. Select System Information with the arrow keys on the remote control and then press ENTER.
  6. On the TV screen, if the version number is 001.491 or higher (the 1st and 2nd zeros of the software version number can be ignored), you already have the most recent firmware version.
Important Notice
  • Read the instructions carefully or you may damage your AV Receiver.
  • Do not turn off the AV Receiver or disconnect it from AC power while it is updating.
  • Do not press any buttons, except the ones mentioned in the instructions.
  • Do not pull out the power cord while the software is downloading and updating. It may cause the system to fail.
Download & Install
There are two ways to update the firmware:
  • Updating via the Internet (recommended)
  • Update via USB Memory Device and your computer
We recommend this method as it's the simplest way to update. It usually takes about 15–30 minutes. First set up the equipment, then download the update from the Internet.
What You Need:
  • an active internet connection (using a wireless router)
  • a compatible TV
Set Up the Equipment:
  1. Turn on your TV and check that the input your AV Receiver is connected to has been selected. (So if the AV Receiver is connected to the HDMI2 port, choose HDMI2 as the input)
  2. Connect the AV Receiver to your internet source using a wireless router.
  3. Turn on the AV Receiver.
  4. On the remote control, press HOME and wait until you see the HOME screen.
  5. When you use Sony wireless rear speakers/subwoofer (not supplied), turn on each speaker and make sure the connection with the receiver is established. Refer to the Help Guide for details on how to connect the speakers.
Step 1: Install the Update
  1. At the HOME menu, use the arrow keys on the remote control to select Setup → Software Update → Network update, and then press ENTER.
  2. When the message “Update to a new software version. Never turn off the power while performing the update. Current version 00x.xxx New version 001.491” is displayed on the TV screen, select OK using the remote control and then press ENTER.
  3. The message “Update Caution” is displayed on the TV screen. Select OK using the remote control and then press ENTER.
  4. The AV Receiver downloads the firmware data from the Internet.
  5. After downloading, the AV Receiver restarts, and the main unit update starts. While the main unit is updating, the update progress status XX% is displayed on the front panel display.
  6. Once the main unit is updated, the AV Receiver will automatically restart again. If an update for the subwoofer or rear speakers is required, it will start at this point.
  7. The update is complete when the finish message appears on the TV.
Step 2: Confirm That the Update Was Successful
Check the firmware version. If the version number is 1.491, the firmware update was successful.
Troubleshooting
What to do if you have problems updating your AV Receiver firmware using the internet.
  • The message “The device is not connected to network. To update, your AV Receiver needs to be connected to the Internet.” is displayed on the TV screen. If you cannot perform the Update via Internet, try the Update via USB Memory procedure.
    1. Make sure the router and all devices connected between the AV Receiver and the router are switched on.
    2. Make sure all the cables between the AV Receiver and the router are correctly connected.
    3. Try the update procedure again.
  • After the Update via Internet procedure has started, the message “Download capacity: xxxxxxKB/xxxxxKB and xx% is display in TV screen” is displayed but the progress bar on the display has not changed.
    Depending on the network connection, the Update via Internet procedure can take a long time (up to 60 minutes). That is why the message “Download capacity: xxxxxxKB/xxxxxKB and xx% is display in TV screen” is displayed and the progress bar on the display will not change for a long time.
  • When running the Update via Internet procedure, the TV displays the message, “Connection status cannot be confirmed. Cannot communicate with the server. Please try again later.” and you cannot perform the firmware upgrade.
    1. Make sure your wireless network is connected.
    2. Make sure you have confirmed whether or not your AV Receiver has its own IP address in the network settings. (If you use a proxy server, type the IP address of the proxy you use into the Proxy Server field instead of the proxy host name.)
    3. Try the update again.
  • The power went off while the update was in progress.
    Turn the AV Receiver on and try the update again.
  • The update has been going on for over 60 minutes and hasn't finished.
    If the problem continues, the network transmission speed may be low. In that case, update your system following the Update via USB Memory procedure.
  • The message “Already Updated” is displayed on the TV screen.
    The firmware version currently installed on the AV Receiver is the latest version
Update via USB Memory Device and Your Computer
We recommend you use the Internet to update if you can. If not, you can use this method instead. You'll download the update to your computer, transfer it to a USB memory device, then transfer it to your AV Receiver.
Preparations for Firmware Update
Before downloading the firmware, please ensure that your computer is running one of the following operating systems and prepare a USB flash drive.
Operating Systems
  • Windows 11
  • Mac OS X
  1. Read and agree to the terms and conditions.
  2. Download the file AN10STR-1_491.zip to your computer, making sure to remember the directory.
  3. Find the file on your computer, right-click it, and click Properties. Check the size is 621 MB (652 130 722 bytes).
Transfer the Files to the USB Storage Device:
  1. Extract the update file from the AN10STR-1_491.zip file.
    • For Mac OS X operating system:
      1. Go to the location where the file was downloaded and double-click the AN10STR-1_491.zip file.
      2. A new file will be created called F_NSTR0.UPG.
    • For Microsoft Windows operating system:
      1. Go to the directory where the file was downloaded, right-click the AN10STR-1_491.zip file, and then click Extract All.
        Note: For Windows, the default settings for Microsoft Edge will save the file in the Downloads folder. To locate the Downloads folder, click the Desktop tile from the Start screen and then locate the downloaded file using Windows Explorer.
      2. At the Extract Compressed (Zipped) Folders window, click Extract.
      3. A new file will be created called F_NSTR0.UPG.
  2. Connect a compatible USB storage device to your computer.
  3. Transfer the F_NSTR0.UPG file to the USB storage device:
    • For Mac OS X operating systems: Drag and drop the F_NSTR0.UPG file to the root folder of the USB device.
    • For Windows operating systems:
      1. Go to the directory where the folder was created, and then right-click the F_NSTR0.UPG file.
      2. From the menu, click Send To..., and then click the drive that represents your USB device (e.g. Removable Disk E:).
      3. The F_NSTR0.UPG file will be copied onto your USB device.
    Note: The update will not be performed if the folder is not copied to the root directory of the USB device or if the name of the folder is modified.
  4. After copying the F_NSTR0.UPG file, remove the USB device from your computer
Transfer the Update to Your AV Receiver
First, get the equipment ready, then transfer the update to your AV Receiver.
Get the Equipment Ready:
  1. Turn on your TV and check it is tuned to the input your AV Receiver is connected to. (So if the AV Receiver is connected to the HDMI2 port, choose HDMI2 as the input).
  4. When you use Sony wireless rear speakers/subwoofer (not supplied), turn on each speaker and make sure the connection with the receiver is established. Refer to the Help Guide for details on how to connect the speakers.
  5. Insert the USB that contains the F_NSTR0.UPG file.
Transfer the Update:
  1. At the HOME screen, using the arrow keys on the remote control, select Setup → Software Update → USB update, and then press ENTER.
  2. When the message “Update to a new software version. Never turn off power while performing the update. Current version xxx.xxx New version 001.491” is displayed on the TV screen, select OK using the remote control and then press ENTER.
  3. When the message “Update Caution” is displayed on the TV screen, select OK using the remote control and press ENTER.
  4. The AV Receiver downloads the firmware data from the USB memory device.
Troubleshooting
What to do if you have problems updating your AV Receiver firmware using your computer and a USB Memory.
  • A UPDT and ERROR are displayed alternately on the front panel display.
    1. Turn off the system and disconnect the AC power cord.
    2. Turn on the power of the AV Receiver.
    3. Try the Update via USB Memory procedure again.
    Turn on the AV Receiver and follow the Update via USB Memory procedure again.
  • The AN10STR-1_491.zip update file I downloaded from the website cannot be extracted.
    Did you download the file successfully? Delete the file and download it again.
    1. Disconnect the AC power cord from the mains, then reconnect it after several minutes.
