Music Center for PC version 2.7.3
Check the Main notes below before executing the update.
Main notes
IMPORTANT: Note that once the update is installed, you cannot return to the previous version.
Internet Connection and IP address
User data such as IP address or device details are used when the product is connected to the internet for software update or for receiving third-party services.
For software updates, these user data might be sent to our update server to provide you a correct software update for your device.
If you do not want to provide such user data, do not switch on your wireless internet function or insert cable to connect to the internet.
You can download the system software (firmware) for Music Center for PC version 2.7.3 after agreeing with the notes above.
