Select your model category to check if your device is playing in DOLBY ATMOS format.
Sound Bar (models with prefix HT)
- Press the DISPLAY button on your remote control. The current output audio format will appear on the connected TV screen.
- When Dolby Atmos content is playing, the display shows the characters such as DOLBY ATMOS
Multi-Channel AV Receiver (models with prefix STR)
- Press the DISPLAY MODE or DISPLAY buttons on the panel several times. The current output audio format will appear on the TV screen.
- When Dolby Atmos content is playing, the display shows the characters such as DAtmos or DOLBY ATMOS.
Additional notes
- During 4K output on an Ultra HD Blu-ray disc, playback information such as DOLBY ATMOS may not appear on the TV screen even if you press the DISPLAY button.
- When the unit is set to TV input, playback information will not appear even if you press the DISPLAY button.
- For how to playback the Dolby Atmos contents, or how to connect the TV and the components, refer to the How to play Dolby Atmos format audio using a Multi-Channel AV receiver or Sound Bar article.
