Article ID : 00266116 / Last Modified : 20/01/2026Print
Unable to transfer files using the HAP Music Transfer app on a macOS computer
    How can I use the HAP Music Transfer app to transfer files on macOS 11.3.1 or later?
    If you're having issues using the HAP Music Transfer app to transfer files on macOS 11.3.1 or later, please follow the steps below to change the SMB Version in the player.
    NOTE: Before proceeding, make sure the player and the HAP Music Transfer app are both updated to the most recent version available.
    1. With the player in Standby mode, press and hold the HOME button, then press the Power button. The Special Mode screen appears.
    2. Turn the jog dial to select SMB Version and press ENTER.
    3. Turn the jog dial to change from 1.0 - 3.1.1 (default value) to 1.0 and press ENTER.
    4. The screen will return to the Special Mode screen. Turn the jog dial to select Restart and press ENTER.
    After the device restarts, use the HAP Music Transfer app to transfer files.
