Article ID : 00412605 / Last Modified : 28/09/2026Print
    macOS Tahoe (macOS 26) Compatibility Information for Digital Camcorders
    Compatibility is verified for the following products:
    IMPORTANT: Performance is not guaranteed for all computers.
    4K Handycam Camcorders
    • FDR-AX43: Compatible
    • FDR-AX43A: Compatible
    • FDR-AX45: Compatible
    • FDR-AX45A: Compatible
    • FDR-AX60: Compatible
    Note: AVCHD videos may not play on your computer if you import only a single AVCHD file — specifically, when that file is the only content on your camera.
    Cinema Line cameras
    • ILME-FR7: Compatible
    • ILME-FR7K: Compatible
    • ILME-FX3: Compatible
    • ILME-FX6T: Compatible
    • ILME-FX6TK: Compatible
    • ILME-FX6V: Compatible
    • ILME-FX6VK: Compatible
    • ILME-FX30: Compatible
    • ILME-FX30B: Compatible
    • PXW-FX9T: Compatible
    • PXW-FX9V: Compatible
    Interchangeable Lens Camcorders
    • ILX-LR1: Compatible
