Article ID : 00410494 / Last Modified : 01/09/2026Print
    What wireless speakers are compatible with Party Chain?
    With the Party Chain function, you can enjoy music playback on up to 100 compatible speakers.
    Devices compatible with the Party Chain function
    • ULT TOWER MAX (SRS-ULT3000)
    • ULT TOWER 7 (SRS-ULT700)
    • ULT TOWER 5 (SRS-ULT500)
    Notes:
    • Party Chain connects speakers using the Auracast broadcast.
    • Make sure you update all connected speakers to the latest software version.
    • For details on how to set up the Party Chain function, refer to your speaker's Help Guide.
    • Party Chain-supported models cannot be connected to speakers that support the Wireless Party Chain function or the Party Connect function, as these are all separate functions and are not compatible with each other.
