Article ID : 00408026 / Last Modified : 26/10/2026Print
    Applying Distortion Compensation to X-OCN Clips Captured with E-mount Lenses
    Lens distortion compensation for X-OCN clips captured with E-mount lenses made by Sony or license partners is available with the following Sony software and plug-ins.
    Choose which software or plug-in to use based on your non-linear editing (NLE) software as follows.
    Notes:
    • Catalyst Prepare is not available in Mainland China.
    • For information on license partners, see the following page.
      E-mount License Partners
    • Distortion compensation is not available for clips recorded on VENICE/VENICE 2 cameras.
    • Distortion compensation is not available for X-OCN clips recorded in the S&Q or Interval Rec mode on BURANO cameras.
    • To apply distortion compensation in Catalyst Browse, Catalyst Prepare, or Catalyst Prepare Plugin, set SteadyShot to [Off] on the camera before shooting.
      If you will use lenses listed on the following page, check in advance how any distortion will look.
      E-mount Lens Distortion Compensation for X-OCN Clips
    Distortion compensation using Catalyst Browse, Catalyst Prepare, Catalyst Prepare Plugin for Premiere, or Catalyst Prepare Plugin for DaVinci Resolve*
    • Lens distortion compensation using Catalyst Browse / Catalyst Prepare
      1. Select the clip.
      2. Execute [Adjust clip].
      3. Configure settings such as [Stabilization] and [Lens distortion compensation] and then execute [Analyze].
      4. From [Export], adjust the output format as needed and then export the clip.
      For details, refer to the Help Guide.
      Image of operating screen
      Catalyst Browse / Catalyst Prepare operating screen (step 3)
    • Lens distortion compensation using Catalyst Prepare Plugin for Premiere
      1. Select [Video Effects] - [Catalyst Prepare Plugin] and then apply [Adjust clip] to the clip on the timeline.
      2. From [Effect Controls], apply [Lens distortion compensation] and then execute [Analyze].
      Adobe Premiere operating screen (steps 1 and 2)
    • Lens distortion compensation using Catalyst Prepare Plugin for DaVinci Resolve
      • From the cut page
        1. Select [Effects] - [Catalyst Prepare Plugin] in the effect library and then apply [Adjust clip] to the clip on the timeline.
        2. Select [Inspector] - [Effects], apply [Lens distortion compensation], and then execute [Analyze].
        DaVinci Resolve cut page (step 1)
        DaVinci Resolve cut page (step 2)
      • From the color page
        1. Select [Catalyst Prepare Plugin] - [Adjust clip] in the effect library and then apply compensation to the clip.
        2. In the effect settings, apply [Lens distortion compensation] and then execute [Analyze].
        DaVinci Resolve color page (steps 1 and 2)
    • *Shooting with a Sony E-mount lens for which [Distortion Comp.] is locked to [Auto] on the camera automatically activates lens distortion compensation.
    • *Some features of Catalyst Prepare Plugin for Premiere and Catalyst Prepare Plugin for DaVinci Resolve, other than lens distortion compensation are paid features. A watermark is applied to clips when paid features are used without a subscription.
    • *For NLE software details, contact the software vendor.
    • *Adobe and Adobe Premiere are registered trademarks or trademarks of Adobe Inc. in the United States and other countries. DaVinci Resolve is a registered trademark or trademark of Blackmagic Design Pty. Ltd.
