Article ID : 00401465 / Last Modified : 13/10/2026Print
    Sound from the subwoofer is too low when it is connected directly to Sony’s BRAVIA TV via Wi-Fi
    What is the sound of the subwoofer?
    Since a subwoofer is designed to play bass sounds, when you play an audio source that has fewer low frequencies, the sound from the subwoofer can be harder to hear. To make sure the subwoofer outputs sound properly, try playing an audio source that will make it easy to confirm the bass sound, such as a movie.
    Make sure the subwoofer is connected and turned on
    Make sure that the subwoofer is properly connected to the soundbar, and that the subwoofer's indicator lights up.
    Adjust the bass bolume
    Turn up the Bass level in the BRAVIA Connect app's remote control screen or BRAVIA TV's Quick Settings.
    Related article
    If the issue is not resolved, refer to the No sound comes from the subwoofer when it is connected directly to Sony’s BRAVIA TV via Wi-Fiarticle.
