Article ID : 00411189 / Last Modified : 07/09/2026Print
    macOS Tahoe (macOS 26) Compatibility Information for Application Software
    The compatibility of the following software applications has been verified:
    IMPORTANT: The operation of these software applications is not guaranteed for all computers.
    Application Software Version Applicable Product Categories macOS 26
    (Tahoe)
    Notes
    Imaging Edge Desktop (Remote/Viewer/Edit) Remote/Viewer/Edit: 4.0.00 Check the supported devices Compatible Download page: https://support.d-imaging.sony.co.jp/app/imagingedge/l/download/
    IPTC Metadata Preset 1.4.00 Check the supported devices Compatible with Apple Silicon Macs only. Intel-based Macs are not supported. Download page: https://support.d-imaging.sony.co.jp/app/iptc/l/download/
    Remote Camera Tool 5.1.01 Check the supported devices Compatible Download page: https://support.d-imaging.sony.co.jp/app/remotecameratool/l/download/
    Imaging Edge Webcam 1.2.00 Check the supported devices Compatible with Apple Silicon Macs only. Intel-based Macs are not supported. Download page: https://support.d-imaging.sony.co.jp/app/webcam/l/download/
    Catalyst Browse 2025.3 ― Compatible Download page: https://www.sony.net/catalyst/help/
    Catalyst Prepare
    (2026.1.1 or earlier)
    Catalyst Prepare
    (ver. 3.0 or later)
    3.0 ― Compatible Download page: https://www.sony.net/catalyst/help/
    Catalyst Edit 2025.3 ― Compatible Download page: https://www.sony.net/catalyst/help/
    Catalyst Prepare Plugin for Premiere Pro 2.2 ― Compatible Download page: https://www.sony.net/catalyst/help/
    Catalyst Prepare Plugin for DaVinci Resolve 2.2 ― Compatible Download page: https://www.sony.net/catalyst/help/
