Article ID : 00382160 / Last Modified : 26/07/2026Print
    Compatible outputs of the devices required when charging or supplying power to batteries (NP-SA100) with the camera body or a battery charger (BC-SAD1)
    The compatible outputs of the devices required to charge or supply power to batteries (NP-SA100) vary depending on the combination of your camera, charger, and other devices. Check the compatibility tables below and then use a USB Type-C® cable (USB-C® - USB-C) and a USB PD (USB Power Delivery) compatible device, such as an external power supply, that are compatible with the required outputs. If you use devices that do not meet these conditions, it may not be possible to properly charge or supply power.
    Note: Please refer to the information below for the compatible outputs of the devices required when supplying power with a DC coupler.
    Compatible outputs of the devices required when supplying power to cameras with a DC coupler
    When charging or supplying power with the camera
    Illustration of charging a battery (or supplying power to the camera) by inserting the battery into the camera and then using a USB Type-C cable (USB-C – USB-C) to connect the camera to the USB Type-C terminal of a USB PD compatible device
    Compatible outputs of USB PD compatible devices (USB Type-C cable and external power supply)
    • ✓ Available
    • - Not available
      Under 27 W 27 W or more
    When charging ✓*1
    When supplying power ✓*2
    • *1 Charging is possible but may take some time.
    • *2 Supplying power is possible, but battery consumption may increase.
    When charging with a battery charger (BC-SAD1)
    Illustration of charging batteries by attaching them to a battery charger and then using a USB Type-C cable (USB PD compatible) to connect the battery charger to an external power supply (USB PD compatible)
    • ✓ Available
    • - Not available
    Number of batteries Under 18 W At least 18 W / Under 27 W At least 27 W / Under 45 W 45 W or more
    1 ✓*1
    2 ✓*1 ✓*1
