Article ID : 00369721 / Last Modified : 27/04/2026Print
    The sound quality is low, noise occurs, or the sound skips (INZONE H6 Air / INZONE E9)
    If the sound quality is low
    • If the volume of the playback device (e.g., PC, PlayStation®5) is too loud, lower the volume.
    If noise occurs or the sound skips
    • If your headphones are connected to a computer, check that the USB Type-C® audio box is properly connected to the computer's USB Type-C port.
    • If your headphones are connected to a PS5™, check that the mini plug is properly connected to the mini jack of the PS5 controller.
    Notes:
    • Dropping the computer while the USB Type-C audio box is connected, or applying excessive pressure to the USB Type-C audio box, may damage or warp the USB port. In such cases, you may have to pay for repairs, even during the warranty period.
    • If you connect your headphones to the computer when there is high system usage, noise or sound interruptions may occur. This is not a malfunction. Closing unnecessary apps or tabs may help improve the issue.
