ZV-E10M2: Using an optional shooting grip
You can use an optional GP-VPT2BT shooting grip as a remote control by pairing it with the camera over a Bluetooth connection.
The grip also serves as a tripod, so you can enjoy many styles of shooting.
Connecting to the GP-VPT2BT
For Bluetooth pairing instructions, see the following page.
Pairing the unit with the mounted camera
Using the GP-VPT2BT
- A:
- Flip button
- B:
- Angle adjustment button
- C:
- PHOTO button
- D:
- Zoom button
- E:
- C1 button
- F:
- Adjustment wheel
- G:
- Indicator
- H:
- MOVIE button
- I:
- LOCK switch
Use the C1 button on the grip as you would use the C1 button on the camera.
The shooting grip can also be used as a mini tripod, which makes it even more useful for livestreaming.
When using the grip as a tripod, make sure that the total weight of the camera and lens does not exceed 1.5 kg.
Note that when the grip is used as a tripod, it may tip forward even if the load is within the maximum weight limit, depending on the lens and conditions of use.
For livestreaming details, see the following page.
Livestreaming videos
For GP-VPT2BT product information and instructions, see the following pages.
All images used here are provided for illustrative purposes only.
