Article ID : 00293761 / Last Modified : 25/05/2023Print
Xperia 10 III software release overview
    Welcome to the Xperia 10 III software release page.
    • Each Xperia smartphone receives security and software updates throughout its lifecycle
    • Software release timings may vary per country and operator
    Latest software release
    DateSoftware versionSoftware improvement
    2023
    March
     62.2.A.0.428
    • Security patch update to 2023-03-01
    • Google Mobile Services Package update
    • Operator requested changes
    • Music updates thanks to market feedback
    How to check the software version and how to update your Xperia smartphone
    Tip: To check your device's current software version, find and tap Settings → About phone → Build number.
    When a software update is available, Refresh Icon appears in the status bar.
    To download and install a system update from the Notification panel
    1. If you use a device with multiple users, ensure you are logged in as the owner.
    2. Drag the status bar downwards to open the Notification panel.
    3. Scroll down, select the wanted system update, tap the item, and then tap UPDATE.
    4. When the download is finished, open the Notification panel again if it is closed, then tap RESTART.
    Why hasn't my Xperia phone received an update yet?
    • Software updates are released at different times depending on the operator, market, region or country. Therefore, we cannot give you an exact date for when a specific update will be available for your device. In addition, network operators and specific markets may choose not to use the updates for specific models
    Previous releases
    2023 62.2.A.0.367
    •  Android 13 release
    2022
    November
     62.1.A.0.675
    • November Security Patch level upgrade
    2022
    September
     62.1.A.0.645
    • September Security Patch level upgrade
    2022
    July
     62.1.A.0.617
    • July Security Patch level upgrade
    2022
    May
     62.1.A.0.587
    • April Security Patch level upgrade
