ZV-E1: Using Creators' App
Using Creators' App, you can transfer still images and movies to a smartphone, shoot remotely, and add location information to your images. You can also use this convenient app to set up your camera initially and check the remaining battery and media capacity.
What you can do with Creators' App
These are the key features of Creators' App.
- Set up your camera initially
- Control your camera from a smartphone (remote shooting)
- Import camera images to Creators' App (initiated on your camera)
- Import camera images to Creators' App (performed on your smartphone)
- Update camera system software
- View imported images
For details, see the the following page.
Creators' App Support
Connecting to your camera
If you have not completed the initial camera setup yet
The Connect Smartphone screen appears the first time you turn on the camera after purchase.
Select Connect a smartphone and follow the on-screen instructions.
For detailed instructions, see the following page.
Creators' App: Performing initial setup of the camera
If you did not connect the devices during the initial camera setup
On your camera, select MENU → (Network) →
Cnct./PC Remote → Smartphone Connection and follow the on-screen instructions.
Creators' App: If you did not set up a connection initially
All images used here are provided for illustrative purposes only.
