Article ID : 00287579 / Last Modified : 31/07/2026Print
    Spare parts: Granting your product a second chance
    Spare parts can give you the opportunity to grant your favourite Sony product a second life! Rather than having to purchase a brand-new product, you can often solve a problem by replacing a damaged product part.
    What to do depends on your warranty status:
    If your product is under warranty
    Please contact our support team. Our agents will assist you in getting your product repaired by certified professionals.
    Contact us
    If your product is out of warranty
    You can still have your product repaired at one of our Authorized Service Centers, with the cost depending on the part and issue.
    Find an Authorized Services Center
    Which Sony Spare Parts can I order?
    Notes:
    • External power supplies having identical technical specifications are interchangeable between different television models.
    • Remote controls of different television models have the same core functionalities.
    • Parts relevant to professional repairers are assigned part numbers per model, facilitating the ordering of the correct parts. These part numbers can be found on the service manuals, which professional repairers can request here.
