Article ID : 00287128 / Last Modified : 21/02/2023Print
No sound comes out from the SLS-1A speaker
    • Make sure that the SLS-1A speaker and the connected device are turned on.
    • Make sure that the cables connecting the SLS-1A speaker to your device are firmly plugged.
    • Make sure that playback is in progress on the connected device.
    • Make sure that the sound volume level of the connected device is high enough. (the Signal Level indicator flashes when a signal is detected)
    • Turn off the connected device and then turn it back on.
    • When a device is connected to the analog input (INPUT) terminal on the SLS-1A speaker by a cable, make sure that the cable is firmly plugged.
    • On the [Routing] tab of the Line-Array Speaker Manager application window, make sure that the input source and the sampling rate are specified.
    • After you change the sampling rate, click (reboot) on the [Device] tab to restart the SLS-1A speaker.
    • If you are connecting through a router, using one providing a transmission speed of 1000 Mbps is recommended.
