Article ID : 00288818 / Last Modified : 20/01/2026Print
BRAVIA TV dimensions of X90K - X91K - X92K - X93K - X94K series (55-85)
    These dimensions are approximate values. For the dimensions when using the Sony Wall-Mount Bracket, refer to the Wall-Mount Bracket Installation Information on the product support website.
    Using a stand: Standard position
    TV dimensions labeled A through G
    Unit: millimetre
    Model (XR-, XRM-)A: screen widthB: screen heightC: stand widthD: height with standE: screen depthF: stand depthG: front stand depth
    85X90K, 85X90xK190110901567112580469199
    75X90K, 75X91K, 75X93K, 75X94K, 75X90xK1675962136199279398150
    65X90K, 65X90xK, 65X91K, 65X93K, 65X94K, 65X90xK1452834117486377331130
    55X90K, 55X90xK, 55X91K, 55X93K, 55X94K, 55X90xK1233711102774076331130
    Using a stand: Narrow position
    Unit: millimetre
    Model (XR-)A: screen widthB: screen heightC: stand widthD: height with standE: screen depthF: stand depthG: front stand depth
    85X90K19011090601112580469199
    75X90K167596250999279398150
    65X90K145283444486377331130
    55X90K123371142474076331130
    Using a stand: Sound bar position
    Unit: millimetre
    85X90K, 85X90xK190110901567116580469199
    75X90K, 75X91K, 75X93K, 75X94K, 75X90xK16759621361103279398150
    65X90K, 65X90xK, 65X91K, 65X93K, 65X94K, 65X90xK1452834117490377331130
    55X90K, 55X90xK, 55X91K, 55X93K, 55X94K, 55X90xK1233711102778076331130
    Using a stand: X92K series Standard position
    Unit: millimetre
    75X92K1675962623103985444182
    65X92K145283450990882325126
    55X92K123371151078581325127
    Mounting on a wall
    TV dimensions labeled from A through G
    Unit: millimetre
    Model (XR-, XRM-)A: screen widthB: screen heightC: wall-mount bracket hole distance (W)D: wall-mount bracket hole distance (H)E: bracket hole distance to side of screenF: bracket hole distance to top of screen
    85X90K, 85X90xK19011090400400751549
    75X90K, 75X91K, 75X93K, 75X94K, 75X90xK, 75X92K1675962300300688520
    65X90K, 65X90xK, 65X91K, 65X93K, 65X94K, 65X90xK, 65X92K1452834300300576393
    55X90K, 55X90xK, 55X91K, 55X93K, 55X94K, 55X90xK, 55X92K1233711300300467270
    • G: M6 holes for wall mount bracket
    • For screw length information, refer to the instruction manual.
    For product protection and safety reasons, Sony recommends that mounting your TV on the wall is done by Sony dealers or licensed contractors. Make sure you use the specified Wall-Mount Bracket. For details, refer to the TV manual.
