Article ID : 00266339 / Last Modified : 28/07/2021Print
How to set reminders and never miss your favourite TV programmes
    By setting a reminder on a TV show you'd like to watch, you can be sure to never miss it. The Reminder function will automatically switch your TV programme to the TV show you wanted to watch, just as it's about to begin. It works even when the TV is in standby mode and can be set for up to 18 programmes at a time. Follow the steps in this article to start setting up reminders for your favourite shows.
    How to set a reminder
    How to cancel a reminder
    NOTES:
    • Reminder and Timer REC cannot be set for the same programme simultaneously.
    • If the TV turns on because a reminder had been set on a TV programme, the TV won’t turn off automatically. To make sure your TV doesn't stay on while you're away, please either remove the TV programmes that have reminders set for that time from the Reminder list or enable the Idle TV power off function by following the steps below.
      How to set up the Idle TV power off function
