How to hear audio from high-resolution audio sources using the Wireless Speaker
There are two methods to hear audio from high-resolution audio sources with the Wireless Speaker:
- Select a high-resolution audio source in the streaming service app, and then cast (play) that audio to the speaker.
- Use an audio cable to connect the AUDIO IN port on the speaker and the high-resolution audio output compatible jack the source device. Then, play high-resolution audio on the connected device.
