Article ID : 00259951 / Last Modified : 25/05/2022
Information
    Notification to STR-DN850, STR-DN1050, ICF-CS20BT, and XDR-DS21BT customers
    Please be informed that the following Sony audio devices will not be compatible with future versions of Music Center, starting from Version 5.2 that is scheduled to be released in early August, 2017.
    After the release of Music Center Version 5.2, please use the controls on your audio device or the supplied remote control for device operations.
    [Affected models]
    • STR-DN850/STR-DN1050
    • ICF-CS20BT
    • XDR-DS21BT
    If you prefer to continue using Music Center for device operations, keep your Music Center from being updated to Version 5.2.
    If the automatic update function is set to "On" on your mobile device, please change the setting to "Off" prior to the release of Music Center Version 5.2.
