Article ID : 00375432 / Last Modified : 26/07/2026Print
    The battery will not finish charging inside the camera
    If you use an AC adapter with a low charging capacity (output current) to charge the battery while it is inside the camera, the charging time will be significantly longer.
    • For cameras that support USB PD (USB Power Delivery)
      You can enable fast charging by using a commercially available USB PD-compatible device.
    • For cameras that do not support USB PD
      Please use a USB AC adapter with a rated output current of 1.5A or higher.
    USB PD compatibility and the required output vary depending on your camera model. For details, please check:
    Which Sony cameras support USB PD (USB Power Delivery)?
