Article ID : 00247301 / Last Modified : 20/01/2026Print
    Which Xperia 1 II camera lenses support 20 fps AF/AE (Burst mode)?
    Valid for
    • Xperia 1 II
    Solution
    • 20fps AF/AE (burst) shooting is supported only with the 24mm (wide) camera in Photography Pro.
    • With continuous calculations of autofocus and exposures up to 60 times per second, Burst mode gives you clear, in-focus shots of even fast-moving scenes. It also gives you the Real-time Eye AF on humans and animals.
    • Other lenses support 10fps AF/AE burst with calculations of up to 30 times per second AF/AE.
